smelni
I ran a test to help understand the math of DOF conceptually and got a interesting result but cant really explain it.
Test setup as follows:
camera -> 3 feet -> chart-> 5 feet -> wall
We set the lens to 15 mm and marked on the monitor where the chart height landed. We then put marks on the wall on the edge of frame.
Then we moved the camera back to the following setup
camera-> 6 feet -> chart -> 5 feet -> wall
The camera is now double the distance to the chart - we set the lens to 30mm. this put the chart at the same image size - now however you see less of the wall in the frame.
This is a demonstration of the old trick of backing the camera up to make the DOF seem shallower - but if you consult charts for DOF - the DOF for the chart in this example is the same at both distances becuase the distance doubles and the focal length doubles.
The result of having less of the wall in the frame is that it is "stretched" to fill the frame and therefore looks more out of focus. This makes sense since the chart is double the distance (6 feet) but the wall is less then double the distance so you will see less of the wall.
SO here is the question (if you managed to follow this up to now) - If the DOF around the chart is identical - why is the wall less in focus - it seems that if you extend beyond the DOF the properties of the images are different in the 2 examples - but why is it the same within the DOF but different outside in terms of what is in focus?
a mouthful I know - and hard to explain - but any insight would be helpful
