Does the AF100 have vertical streaking?
cordvision
As far as I know, the AF100 uses the same sensor as the GH2, therefore I was wondering if it also suffers from horizontal streaking under certain conditions. The streaking in the GH2 seems to be a hardware problem, so there's a possibility that it also affects the AF100.
For more info on the streaking problem with the GH2, check this thread --> http://www.dvxuser.com/V6/showthread.php?230484-GH2-Blue-horizontal-banding
Would be awesome if anybody that has access to the AF100 could run some tests....
(Mod: I made a mistake in the title that I can't correct by myself. I meant to say horizontal instead of vertical. Please fix it if you can... thanks)
The AF100 does NOT use the same sensor as the GH2. A simple search on DVXuser reveals this.
Where did you find this information, can you please post a link? I find countless posts on this board and on other boards claiming that the sensor is very likely the same...
Jan and Panasonic have confirmed that it isnt.
There's no streaking on the AF100 anywhere.
This can actually mean many things. But lets wait until we see both mor GH2 and AF100 footage. I am certain the aliasing is way lower on the AF100.
Aliasing should be lower anyways, even if they use the same sensor, because they can use an optical low pass filter that is optimized for HD video and not stills...
