ChrisHarding
Hi Guys
Maybe just a silly question but if you buy your camera from new and turn it on does it automatically load the Scene 1 file by default?? or does it simply not load any files. My question then would be if you change the parameters of both scene files and then physically go thru the menu and load Scene1, when you start the camera again it will always load scene1 until you tell it not to????? Let's say I'm doing an outdoor shoot so I load Scene 1 and use the camera for the day and then, in the evening I need a change cos it's low light so I load Scene2 and thruout the evening Scene 2 is applied each time I turn the camera on?????
Now, what happens if I want to use neither scene file?????
Based on that is there anyway you can tell the camera "don't use any scene files????" or would you have to initalise Scene 1 back to factory defaults and then load scene 1 again???? It would be great to have 2 files stored BUT be able to use neither if you wanted to!!!!
Thanks for any help
Chris
Thanks for any help
Chris
