Do you know if Vegas has its own codec?
Zab
I thought it used the standard microsoft dv codec. I think Premiere uses the Microsoft one...
BTW I always get "pixelated lines" when applying 2 or 3 effects on the image and making transitions.
Do you think that using Vegas I won't have this problem?
Thanks a lot
Zab
Re: Do you know if Vegas has its own codec?
Yes, Vegas has its own codec. It was designed by Sonic Foundry. Tests (especially in the area of generational degredation) have shown this codec to be top notch. If you wanted, you could select to use the Microsoft DV codec in Vegas, but I wouldn't recommend it.
BTW, you said you always get "pixelated lines" with effects and transitions. What NLE is this in? Are you referring to this happening in Vegas? Please clarify.
, ,Re: Do you know if Vegas has its own codec?
Hi! Thanx for the info. I use Premiere 6 but now I'm not sure if I will use it anymore, at least not for capturing... ;-)
So the "pixelated lines" may be coused by the microsoft dv codec?
Zab
