Recently, some of my SD card fleet has become a bit unreliable. I only purchase SanDisk Ultra class 10 cards (was using 8x 16GB cards, all 30MB/s), so I thought I would be safe from this type of issue. I use the SD cards in three different cameras: Panasonic G6, GH3, and GH2. Over time, I noticed that it would take slightly longer to "stop recording." Then there was an instance of the camera freezing up, requiring a battery pull to get it going again (this later happned twice more). At the time, I was relying on the G6 for a lot of my shooting, so I was convinced the camera was at fault, since that camera is more aimed at consumers. However, when the issue began to appear in my GH2 and GH3 (got a "recording stopped due to write speed limitations of memory card" error on the unhacked GH2), I tested my 16GB SD cards vs a new 32GB SD card of the same brand and class, and found the cards to be the issue.
I have had these cards for approximately 2-3 years and have formatted before shooting each time (I would estimate 100-200 times). One of my friends in IT informed me that formatting wears out SD cards faster and recommended that I simply delete the video files manually and not format. However, this goes against what I've read on this forum in the past which is to format every time I put the card in the camera. I'd love to know more about this topic because while I was lucky this time not to lose too many recordings this time, I may not be so lucky if the cards wear out again. I would like to add that I don't mind purchasing new SD cards every year or two if that's the most reliable way to make sure things go smoothly. The cost of the SD cards is peanuts compared to the work being recorded on them.
Many online resources I found say that cards wear out after 10,000 write cycles, and I don't believe I was anywhere near that, which is why I'm asking you guys!
