DO MY LCD and my viewfinder lie????
  • Start date Start date
G
Guest
Guest
HAVE I BEEN DUPED?!?!?
Concerning some stuff I shot on the DVX.
In playback on my LCD, and in the viewfider, the
images are well lit and contrasted, with beautiful
warm skin tones, and well behave highlights & blacks -
just like when we shot them and viewed them on the
monitor.
HOWEVER, when playedback thru: another DV camera,
a regular television, and worst of all, into Final Cut Pro,
the images are dark, low contrast, and have a nasty yellow
'cast' over the entire image--
TELL ME I haven't been filming under a false image thru
the DVX---and that I'm not going to be spending my golden
years chasing color correction all over every scene!!!
what is up here? where is the true image?!?!?!
help! sos!
(rrrrripppp ----the sound of hair being pulled out)
Re: DO MY LCD and my viewfinder lie????
I don't know. It's always the opposite for me in that it's more or less WYSIWYG.
I always find it a little brighter on a tv than I thought, which is of course better than underexposing.
I would LOVE to have WYSIWYG---
could it be my settings that have thrown things
so far off?
I don't know. What exactly are you seeing and how dramatically different is the playback?
Are you using Zebras? One mistake I made early on with the camera is underexposing what I though looked great 'in camera' on the LCD or viewfinder and then on the tv it was always underexposed.
I usually hit the Auto Expose button to start, switch it off and make any adjustments I might need and although I hate Zebras, in the future I will probally hit the button if there are any exposure issues I might be having.
VERY dramatic -
I'm seeing 80% of the contrast lost
and a yellow cast over the entire image---
One other thing...these are dupes recorded
from the DVX onto a Canon XL1 ---I had to send
originals elsewhere----could the Canon be to blame
(BUT keep in mind---the Canon-recorded tapes
STILL look GOOD when played on the DVX LCD)
Personally, I don't put 100% faith in any LCD display (yet). For critical stuff only a properly calibrated CRT monitor will do for me. And, right now, that's your best bet for determining where the problem lies.
Did you white balance your camera? Are the contrast and brightness etc controls set correctly on your TV and or monitor.
..my lcd is also pretty dead accurate. although mine is also brighter on a tv, but i run the cam at 0 ire setup, so the 7.5 setup of the ntsc tele will naturally make the image a bit brighter and washed out by comparison. i have my crt monitor on my nle that displays the nle monitor window set to maximum brightness to match the ntsc monitor output in brightness. its pretty close.
Why not hook your camera up directly to your monitor and/or computer and see what you get directly while also recording to tape?  Then take the tape and capture it and compare.
Just a thought.
Andrew
Crystal Clear Media
