Do I need to apply the patch every time?
anubious
Quick questions: In regards to the hack I noticed if i am not on a full battery when I turn on the camera and I go to press play to it says "Firmware update requires fully charged battery" Does this mean that I am not able to shoot with the hacked settings or does the camera think i am trying to press play and enable the hack? Question 2: Sometimes when I press the play back button after turning on the Camera i get the "Start Version up 1.3" does this mean in order to use the hacked settings i have to do this each time I turn on the camera to shoot? or do I ignore it and continue? (if i ignore it and check the settings i realize its lens firmware and when ignored its 1.1)
let me know.
1. if update was once applied - then may remove firmware file from card.
2. no. Lens firmware and body firmware are different things.
No, the hack is permanent and only needs to be installed once. If you don't want the camera to ask if you want to reinstall the hack when you press the Play button, simply delete the hacked .BIN file from your SD card after you install the hack.
Thank you both! Ipowell your a legend I am currently using your settings, I saved the hack one using the Native 24p and the other is it unchecked, just testing to see if what I am shooting will lock up, what im shooting is mainly by hand and almost is never static.
