I keep getting an issue that the "Battery cannot be used" on the GH5 when using the Dummy Battery connected to a V-mount plate that outputs 7.2 Volts (7.8 volts measured).
The dummy battery works fine with an 8.4 volt dc power adaptor source (8.7 volts measured) but once I connect to a DC supply that produces 7.2-7.8 volts, it will not work.
I have read elsewhere that the camera will behave this way if it receives less than 8 volts.
Aren't the original DMW-BLF19 batteries rated at 7.2 volts??
Are there any dummy batteries out there that actually work with the GH5 using 7.2 volts, or is my best bet to use a d-tap to 8.4 volt converter on my v-mount plate connected to my current dummy battery?
Thank you.
Thank you.
