DIY scrims for outside use
ExposedFilm
Hello everyone!
Im planning an outside morning scene and I'm trying to build a scrim to tone down the sun on the actors' faces. At first I wanted to make it with light coton but I'm afraid it'll act like a sail and be hard to keep still if there's wind. My alternate idea was to use a mosquito screen. In either way I'll stick it to pvc pipes with either tie-wraps or velcro.
Anybody has any experience with DIY scrims?
PS: On a side note, would I be better scrimming or reflecting to fill the shadows?
Thanks a lot!
Hello everyone!
Thanks a lot!
If I were you I'd put the sun behind the actors (off to the side, prolly) and light their faces with a 4X4 oe 4X8 bounce board from the side front so there is some soft modeling of their features. It's a nice look and there are no problems with exposure difference between the faces and background.
I've always like the scrim look - you need a suitable fabric (something a little sheer vs. thick), a frame, and some means of supporting the frame. Anything from a couple guys to a pair of matthews hi-hi's.
A playboy shooter named Arnie Freytag used to stretch giant sheets of nylon up with ropes and no frames - that couple be a possibility for the low end.
Also, you can scrim with black net which cuts light intensity but doesn't soften it much; my favorite is to scrim with a white mesh; cuts highlights and opens shadows, but it's subtle - it can still look like actual "hard" daylight, but it's more flattering and easier on your exposure.
I've done this recently. I used scrim on the light side of the talent's face and a soft white bounce on the dark side. it worked great!
I used plastic porch screen but I ended up needing 4 layers of it to really tone the bright morning sun down enough. I bought it at the last minute because I didn't know we were going to be shooting in direct sun until the day before.
It might be worth the time and money to just find some real scrim material.
This is what I was scared of too. I'll see if I can rent any. So far experiments haven't been really conclusive. I might just end up bouncing instead for this project and investigate a better mesh to build a scrim
We ended up having to scrim and bounce to balance the ND filters and F stops for the intended depth of field as well as keeping the background exposed well.
Here are some stills from the shoot. I think pics 6 and 11 were scrimmed and bounced to keep hair highlights down and face brightness up:
http://www.dvxuser.com/V6/showthread.php?t=220114
