DIY Rain
stephen_nugent
hi,
working on a film where id like to simulate rain on two occasions.
one is an day exterior shot, more or less high angle framing a man OS sitting on a porch when rain begins to pour, not necessarily keeping the sky in shot. Would a powerful hose do if the local fire brigade lends us a hand? And how is this done, by angling the hose upwards until it looks realistic enough in the viewfinder?
second is a night shot, a window rain shot, backlit i guess to enhance the effect. What are the practicalities of doing this, any good DIY setups?
thanks,
stephen.
You could build yourself a rainbird - it's basically a length of pipe, sealed at one end, with a hose fitting at the other, punched full of holes, in between. Rig it at the required height, attach a garden hose, turn on the water and: rain.
Make it out of PVC pipe for probably less than US$25.
thanks sadmax, you referring to the window rain? sounds workable but is there a little more elaborate design that might get that random raindrop effect? Hmm.. maybe i could also include a household fan in the equation..
Actually if you set up several sprinklers on the drip tubing overhead, it makes great looking rain if you're looking for a drizzle. If you want a downpour, get two firehoses and point them up from either side and mess with nozzle settings. It will rain. Remeber hypothermia is easy to catch when you are wet!
Old trick: add a little milk to the "rainwater" for better visibility on screen.
Hope this helps.
Ken
the Screen Skins guy
I did rain one time in a short. We just pointed the hose toward the sky, and when it came back down it looked like rain. It worked okay because the actors (and myself, with my camera wrapped in a trash bag) were actually wet and dripping, in front of them it looked like it was digitally superimposed or something.
Kurosawa added black ink to his rain is Rashomon for visability and it looked great....although sometimes you can see some black smudges on the actors...
