You are wrong. Circuit polariser is required for good AF on DSLRs![]()
it is a long time now that circular polarizer are no more required on most camera. but it does not hurt to check.
a circular polarizer is a linear polarizer with an additional layer to turn light back to a more "normal" behavior.
so if you can go with a linear polarizer it is a good point since they are oprtically better.
the problem with circular polarizer is to find a pair that is matched (it is never indicated on a circ-pol if it turns clockwise or counter clockwise).
and due to the additional layer, circ-polc also need to be mounted the right direction because they are one way.
circular must be first from camera and linear second, that allows work AF as it will be only with circular polrizer.
linear with linear makes fade, and quarter wave plate makes circular polarization.
[camera] <- [circular] <- [linear] <- in that case camera will see circular polarized light - so AF works as best possible with circular polarizer
[camera] <- [linear] <- [linear] <- in that case camera will see linear polarized light - so AF works as it can with linear polarizer
[camera] <- [circular] <- [circular] <- what actually will be between two circular polarizer - no data, it's act in chain: light source -> linear polarization -> quarter wave rotation (right or left) -> linear polarization -> quarter wave rotation (right or left) ... most interesting part are between quarter wave and next linear what will be passed - no information ... possible will be non linear fading effect = on small angle change big fading, and further rotation will be with very small light passing changes ...
[camera] <- [linear] <- [circular] <- in that case camera will see linear polarized light - so AF works as it can with linear polarizer, but notes from previous point also need to be checked ...
(sorry currently have only one circular filter - can't check physically) - so if anyone currenty have circular and linear - they can report what there occurs with light changing on change of angle - if there normal changing on angle change - then simple first from camera filter decide how works AF and light rotation direction by quarter wave plate even wil not be matter....
You can flip a linear polarizer that has no different effect.
With 2 CPL you should flip the front CPL. And you will get the same results as with CPL and linear polarizer in front.
