Carlos_E._Martinez
Some days I had an idea on how to build a light, cheap, easily transportable tripod using PVC tubing.
The idea is to use them for holding LED lights, like the the Z96, which is rather light in weight and has its gravity point right under it... as long as you don't use video batteries.
As I foresee it, height should only be 1.5 meters, as going higher than that might make balance difficult.
My experience with PVC tubing is mostly from building a FigRig clone, so it's rather limited. But I imagine using 25mm tubes, about 50cm long for each section (3 of them), with two joining tubes and a top cap to hold the holding screw.
The main problem are the legs, so I'm thinking of using 45 degrees adapters, three of them, stuck on the base in a "turtle-base" style. The main issue of such an arrangement is that, as I picture it, the legs will be unequal when forming the base.
Suggestions on how to solve that problem would be welcome. Also any other ideas on how to make this project better.
If there were other previous DIY tripod projects here or elsewhere, please do let me know.
