Jason Miller
Zazacast, thank you for those links, I'v found the ones I could open informative. a couple of them are new to me, I hadn't found them in my reaserch. so thank you
This is SO much easier than the one I have planned with 80/20 parts.
Especially with the screw holes already in the rail!
Thanks for the explanation!
And thanks for the link showing the commercial one for $900!
And they use the idea of monopods on the end ... smart!
I`ll order tomorrow![]()
I just wanted to reiterate the good parts that Zaza listed at the beginning of this thread. I ordered the next size up (prior to this thread) and they're almost too much for a slider. My carriage ended up being almost 8 inches long (I'll cut it down) but Zaza's parts list is ideal for this type of project. Cheaper too!
My parts were recommended on another forum and not as ideal as Zaza's.
cheno
LMAO! :beer:Braggart!![]()
Hah -
Well in this case - shorter is better - doesn't need to be much more than 100mm or 4 inches for the maximum slide room - of course that's about the only time shorter is better.![]()
Great post and cool build.
The first thing that comes to mind with mechanical friction systems is stiction (hence the development of wheels, fluid damping, etc)... the same phenomenon that screws the end of your otherwise perfect pan. I've built some stuff using teflon sheet to reasonably good effect, but I'm using mass to overcome a notchy finish and leverage to initiate smooth starts.
So how about this thing? How's the stiction... does that space-age plastic handle that well or do you have to make several attempts at overcoming stiction?
I know this is going to sound nuts... but try spraying some lemon pledge on the rails.
I can't believe how many people have never heard of this... I've been on several pretty big shoots where the dolly wheels were driving everybody nuts... and I broke out the lemon pledge trick to save the day... this is no exaggeration. EVERYBODY who works a dolly should know about lemon pledge by now. EVERY BODY. It is the life-saver of sound... and smooth stops and starts. Try it and report back... just spray a liberal amount on a clean rag and wipe down the rails before you shoot.
And if you're reading this about dolly track... spray it directly on the track... just a quick walking speed down each rail as you hold the spray on. You'll be the hero at the next gig.
