DIY FLO Lighting parts for members only.
MattinSTL
Sound Modulator
I've had several people ask me to sell them the parts that I use for my lights... and since I'm taking a break from them right now I decided I'd open this up to all the members.
Sockets are $5 each... supports are $1.50 each. I bought a TON of different sockets and supports and I can assure you that these are the very best.
If anybody wants to buy all the various OTHER sockets and supports that I've bought then I'll sell them all to you as one single lot... but as I said... they've been collecting dust because they aren't nearly as good as the ones here.
These are for all 2G11 lamps... that means 4 pins at the base and twin tube... so any lamp that looks like the ones in a Diva, CaseLight, FloLight, etc.
I won't keep these up here indefinitely because these parts are one of the things that seperates the hokie from the professional... but with the current DIY threads on flo lighting I figured you guys may want a leg up.
Matt- I'd be very interested these if I had much of clue as to what to do with them. My guess: Mount the sockets in a case, wire in the ballast and, uhhhh, not sure what to do with the supports. Maybe I should get your parts and miracom's dvd.
These are for all the twin tubes like kino, mole, etc. ect. Any twin tube from 36w to 96w... most common is 55w... the support holds the other end of the tube up... opposite the socket.
If you feel up to some construction I can probably hook you up with a complete kit... everything except the shell anyway.
