I've been searching the forum but can't find a thread with specifics about what those of you who are capturing direct-to-laptop (PC) are doing, and what hardware specs are required. I'm talking about real time capture, not streaming from a P2 card in the HVX to the laptop.
In researching, looks like the data flow
DVX200 --> PC w/DVRack HD --> external FW or USB drive
is the biggest "bang for the buck" capture method in terms of capturing large files. If there's another direct-to-PC method that doesn't require DVRack, I'd love to know about that, too. (The nature of what and how we shoot doesn't make P2 cards practical unless we have like 6 of them, and we're going to get a CinePorter when they are available.)
I have an Athlon 64 3200 laptop with probably a gig of RAM running Win XP, and my thought was to use an external USB drive, that way I don't have to get a PCMCIA Firewire card, and can use the internal Firewire port to connect to the HVX. USB 2.0 is 480Mbit/sec, so should be plenty fast enough.
Does anyone have experience with a similar setup? Would there be a notable advantage to using a Firewire drive over USB? Could I capture 1080i / DVCPro-HD with this setup or would I be limited to 720p?
Also, would a RAID-1 (mirrored) drive, such as the G-Raid Mini be slower or faster (or the same as) than a single drive?
Also, has anyone been able to use DVRack + laptop as an adequate monitor for focusing with the HVX?
Thanks for helping this HVX newbie!
