Direct Capture To FCP 5
I made myself a custom laptop stand for my DVX100B which holds my MacBook above the camera. I loaded my FCP 5 disk to it and I have one question: Is there a way I can have device control enabled with the camera in cam mode, not VTR mode? I want to be able to embed the timecode into the metadata without having to manually put it in... Also, how come when I switch to a different capture setting based on the camera settings I change, why will it say "general error" when I try to capture after I switched? I have to close and then re-open the capture window after that... Should I just use a different program like OnLocation instead?
Final Cut Pro stopped at version 5.1.4. Then it moved to FCP 6.0 which was part of FCS2.
There wasn't a version numbered FCP HD 5.6.
The first version compatible with Intel Macs was FCP 5.1.4.
5.0 is for PPC Macs. You should consider upgrading.
