Anyone out there know why when digitizing 24pa footage, it plays fine through the client monitor--everything is in sync with audio, most likely because the camcorder is hooked directly to the monitor. But when I'm editing the clips into my timeline, nothing shows up through the monitor.
In the 'help' section of Xpress Pro 4.5, it says that there should be a delay, because the signal from the computer has to be changed into an analog signal through the firewire to camcorder/deck, so what you see in the monitor is lagging behind your record-side window.
This has proven true with 24pn footage, but working with 24pa footage shows NOTHING when editing.
What gives?
What gives?
