Hi there,
I just started editing some footage shot on my GH5 and was alarmed to see some digital distortion for about 12 frames about 15 minutes into the recording. A screen shot is below.
This is the first time I've ever seen this. I'm wondering if anyone else has ever come across this. On this particular shoot I was using only a single card, so I can't confirm whether it was the writing of the file to the card or the actual capturing. After offloading the footage to my local drive and network, the card was cleared, so I also don't have a way to double check anything on the card (not sure what there would be to check).
The card was a SanDisk Extreme 128GB v30 Class 10. The recording was 4k 23.976 Quicktime MOV with VLog. The file size was 35.5GB. This "glitch" is in the original file (but again, I can't compare to the SD card, but I do use TerraCopy which would have indicated if there was a file difference). I'm on Windows 10, running the second to latest versions of Premiere and Media Encoder. It's seen both in premiere and in Media encoder. Converting the file in Media encoder gives me the same result.
Any thoughts on what could have caused this or suggestions on how to prevent this in the future?
Thank you,
Stephen
Thank you,
Stephen
