Remarkable 100 ISO mid day direct sun test. Set the D16 to D5500 color temp. 24fps/180. Set exposure by high key sun incident meter reading at f/16-f/22 split. UV filter only. Raw view highlight check showed only specular clipping of small areas. Could have exposed using the sunny 16 rule.
In Resolve I set the raw menu to camera metadata decode, set color management to an ARRI Log-C timeline and output to REC709 2.4 gamma. No other adjustments applied.
ISO rating is dead on accurate. Had a similar result at 200 ISO. The new color matrix is very neutral with correct vectors now.
