I took my Deity Connect system on a shoot today in a warehouse that is an audio nightmare. All metal frame tilt up concrete building with lots of exposed metal girders,
the entire ceiling above it is aluminum sheeting. The building is basically a giant Faraday cage, https://en.wikipedia.org/wiki/Faraday_cage cell phones barely work in there either.
As expected, the Deity Connect wouldn't even work at 5' away, drop out city. Have not yet had a chance to try a UHF system there, but the Connect was useless there.
I need to get
some Lectros to have UHF covered too, I know.
Get an RF Explorer. About $180 on Amazon.
I find that the built-in freq scans on most wireless receivers, whether on the level of Sennheiser or on the level of Lectro, leave a lot to be desired. It only sweeps across the spectrum looking at momentary RF samples. The RF Explorer allows for a full, constant, and realtime look at the spectrum to see where the holes actually are. From there, you can manually coordinate your systems.
Take a look at the newer kit from Wisycom. Quad receiver and four transmitters for about the cost of a dual-channel Lectro system. The only quirk I know of at this point is that all 4 have to be tuned within a 30MHz range, with the first receiver channel serving as the center point. It’s a little weird, even though the systems cover a very wide band. But still, it offers a bit of bang for the buck.
When it gets to this point, I'd rather hire a pro. My cutoff is about at a Mix Pre 10 II and a couple of used Lectros or I might possibly try the Senn G4 with antenna mods like you recommended. Once we're up in the $5-$6K range, hire a pro. ;-)
... Prior to getting an RF explorer, I could not use G2/3s for much of anything in NYC, ...
Because of their 30mw limitation or?
