DGW
It looks like this topic has been discussed in detail but I couldn't find an answer searching the long threads....sorry in advance if I missed it.
Does the DEFAULT setting for frame rate equal the exact same actual rate selected by the recording format? In other words, if I select 720p24PN and use DEFAULT is it the same thing as using 720p24PN with frame rate set to 24FPS? Likewise, if shooting 720p30P with DEFAULT, would that be identical to shooting 720p30P with frame rate set to 30FPS?
