This guy always has great looking footage for his spots using the 5D III
http://vimeo.com/41163912
It does look weird now that you mention it.It's very professional looking; however, one thing I didn't like was how the other diners appeared behind close-ups of the blond. Freeze it at 0:24 to see. They look like cartoons. I can't believe the 70-200 would render out of focus areas like this, must have been done in post as a side effect to what they were changing.
Thanks for posting. I will give 5D to RGB a try and see if there is an improvement from just putting the files on the Edius timeline.
Editing was done in Final Cut Pro 7. I used the standard FCP sharpening filter with a setting of 20%. Color correction was done with "Colorista 2" followed by the "Broadcast Safe" filter. I also added a slight amount of soft vignetting to some shots. Very little color correction was needed and most was just lowering black levels.
The camera was set at 1080P 23.98 using all "I" frame compression. (No external recorder was used for the video or audio.)
The lighting setup was pretty simple. We used 3, 1200 watt Arri HMI's outside the restaurant to supplement the morning sunlight. Sarah is lit using a 3' x 3' Chimera with a 400 watt HMI "Joker". 2 layers of diffusion material is on the front side of the Chimera. All the restaurant florescent ceiling lights were either removed from their sockets or replaced with 5000ºK bulbs.A daylight balanced Kino-Flo is suspended above and behind her head for soft back light. For fill, there's a clean white card on the table in front of her and a 4' x 4' breadboard reflector to her right. This setup also insures that there is only one highlight in Sarah's eyes in her close-ups.
Yep. It also helps when you shoot attractive models...The major reason it looks professional is not because of using Marvels picture style or All-I or 5D to RGB or sharpening or Colorista it looks professional because it was lit properly
The improvement comes from the post process: grading, sharpening, ect. I'm sure it didn't look like this coming out of the camera.
Looks nice except the blown out, white out windows in the background on the spokesperson shots. Of course it's subjective because every DP is looking for their own style, and with Sarah up front, few will notice the background anyway.
I'd opt to bring up the key and fill lights up a few stops on the talent with lighting and save something outside to work with in post.
It would be interesting to see what DR the BMCC could do to balance the interior and exterior. I've seen some very dramatic control on similar blown out interior exterior scenarios with the raw files.
Bottom line is he's working and I'm assuming paid for it.
In the video information he states quite clearly why the windows were blown out: ugly rainy conditions. Makes sense to me.
Nice little spot - though I cant help but think if I delivered that I'd be questioned about that background. Same conditions I think I may have gone for some diffusion over the exterior of the windows which would stop them down but also give them that blown out look but with a nice rolloff.
