Damaged stock lens
Filip Staresinic
Hi. During filming last fighting scene one of the actors accidently bumped with his hand to my HVX stock lens, no need to describe my feel then. At first look everything seems OK but later I noticed that when I grab the lens and try to move it to check how are they holding with HVX body I noticed there is slight movement betwen those two. You know, on the joint that comes after zoom ring where the lens is attached to hvx body, there is a small movement when aplyed a little bit bending (not turning) force. I am not sure that this was like this before. Please if someone can help me and say is this normal or not?
With picture everything looks ok but I don't know what it's going to be when I attach SGpro wich will probably add a little bit tension to this joint as it is very difficult to level those two perfectly.
