[FS: General] Da-Lite 9x12 screen with Optoma projector - $1,100
LeftofCen
Fast-Fold Deluxe Screen by Da-Lite
The Fast-Fold Deluxe by Da-Lite is constructed of sturdy 1.25" square aluminum tubing and features easy release latches for simple, quick set up and tear down of the screen.
Available with Da‑Mat®, Da‑Tex® (Rear), High Contrast Da‑Tex® (Rear), and Dual Vision fabrics. Optional Ultra Wide Angle (Rear) and 3D Virtual Black (Rear) can be requested and quoted separately. All Fast-Fold® Deluxe surfaces are interchangeable with Standard Fast‑Fold® surfaces for easy substitution.
All screen surfaces are seamless and have reinforced black webbing on all 4 sides for strength and durability, and attach to the frame with metal snaps. There are also protruding snaps along the bottom edge to attach a skirt (sold separately, please ask for a quote).
Each deluxe screen includes a rugged wheeled poly carrying case, which meets or exceeds Air Transport Association (ATA) Specification 300 standards.
Fabric Description​
This screen features Da-Mat fabric, which is comparable to the Matte White fabric found on Da-Lite's Wall and Tripod screens. It is very flexible, and can be folded or rolled for easy storage. This fabric is best used where the ambient light conditions can be precisely controlled and a wide viewing angle is required. It is also perfect for high-end projectors that do not need any enhancement for the image.
Projector
[TABLE="width: 100%"]
[TR]
[TD="colspan: 2"]Description[/TD]
[/TR]
[TR]
[TD="colspan: 2"]Optoma's 2300 lumens EP 739 is a versatile and portable multimedia projector. The EP 739 is perfect for a wide range of environments from boardroom to classrooms. Designed with today's demanding business needs in mind, this robust and compact DLP multimedia projector will shine brightly when it comes to high quality presentation.[/TD]
[/TR]
[TR]
[TD="colspan: 2"]Product Identifiers[/TD]
[/TR]
[TR]
[TD="width: 35%"]Brand[/TD]
[TD="width: 65%"]Optoma[/TD]
[/TR]
[TR]
[TD="width: 35%"]Model[/TD]
[TD="width: 65%"]EP739[/TD]
[/TR]
[TR]
[TD="width: 35%"]MPN [/TD]
[/TR]
[TR]
[TD="width: 35%"]UPC[/TD]
[TD="width: 65%"]796435115944[/TD]
[/TR]
[TR]
[TD="colspan: 2"][/TD]
[/TR]
[TR]
[TD="colspan: 2"]Key Features[/TD]
[/TR]
[TR]
[TD="width: 35%"]Type[/TD]
[TD="width: 65%"]DLP[/TD]
[/TR]
[TR]
[TD="width: 35%"]Native Resolution[/TD]
[TD="width: 65%"]1024 x 768[/TD]
[/TR]
[TR]
[TD="width: 35%"]Display Technology[/TD]
[/TR]
[TR]
[TD="width: 35%"]Image Brightness[/TD]
[TD="width: 65%"]2500 ANSI lumens[/TD]
[/TR]
[TR]
[TD="width: 35%"]Contrast Ratio[/TD]
[TD="width: 65%"]2000:1[/TD]
[/TR]
[TR]
[TD="width: 35%"]Form Factor[/TD]
[TD="width: 65%"]Portable[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD="colspan: 2"]Image[/TD]
[/TR]
[TR]
[TD="width: 35%"]Max Resolution[/TD]
[TD="width: 65%"]1400 x 1050 (SXGA+)[/TD]
[/TR]
[TR]
[TD="width: 35%"]Image Size (Diagonal)[/TD]
[TD="width: 65%"]24.6 in. - 300 in.[/TD]
[/TR]
[TR]
[TD="width: 35%"]Image Aspect Ratio[/TD]
[TD="width: 65%"]16:9 (Wide Screen), 4:3, 4:3 (Standard), 5:4[/TD]
[/TR]
[TR]
[TD="width: 35%"]Video Modes[/TD]
[TD="width: 65%"]Cinema, Game, Standard[/TD]
[/TR]
[TR]
[TD="width: 35%"]HDTV Formats[/TD]
[TD="width: 65%"]1080i, 480i, 480p, 720p[/TD]
[/TR]
[TR]
[TD="width: 35%"]Screen Distance[/TD]
[TD="width: 65%"]3.9 ft. - 40 ft.[/TD]
[/TR]
[TR]
[TD="width: 35%"]Synchronization Range Horizontal[/TD]
[TD="width: 65%"]15-100 kHz[/TD]
[/TR]
[TR]
[TD="width: 35%"]Synchronization Range Vertical[/TD]
[TD="width: 65%"]43-120 Hz[/TD]
[/TR]
[TR]
[TD="width: 35%"]Analog Video Format[/TD]
[TD="width: 65%"]NTSC, NTSC 4.43, PAL, PAL-M, PAL-N, SECAM[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD="colspan: 2"]Technical Features[/TD]
[/TR]
[TR]
[TD="width: 35%"]Platform[/TD]
[TD="width: 65%"]Mac, PC[/TD]
[/TR]
[TR]
[TD="width: 35%"]Audio Output[/TD]
[TD="width: 65%"]Speaker(s)[/TD]
[/TR]
[TR]
[TD="width: 35%"]Operation Noise[/TD]
[TD="width: 65%"]32 dB[/TD]
[/TR]
[TR]
[TD="width: 35%"]Front Panel Controls[/TD]
[TD="width: 65%"]Keypad[/TD]
[/TR]
[TR]
[TD="width: 35%"]Connectors[/TD]
[TD="width: 65%"]Component, Composite (RCA), DVI, S-Video, USB[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD="colspan: 2"]Interfaces[/TD]
[/TR]
[TR]
[TD="width: 35%"]Interface[/TD]
[TD="width: 65%"]Serial (RS232), USB[/TD]
[/TR]
[TR]
[TD="width: 35%"]Video input[/TD]
[TD="width: 65%"]15 Pin D-Sub VGA (& component), 15 Pin D-Sub VGA (component), 4 Pin - Mini DIN (S-Video), Composite Video, DVI[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD="colspan: 2"]Lamp[/TD]
[/TR]
[TR]
[TD="width: 35%"]Lamp Type[/TD]
[TD="width: 65%"]SHP[/TD]
[/TR]
[TR]
[TD="width: 35%"]Light Source Power[/TD]
[TD="width: 65%"]200W SHP[/TD]
[/TR]
[TR]
[TD="width: 35%"]Light Source Life[/TD]
[TD="width: 65%"]3000 Hours[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD="colspan: 2"]Dimensions[/TD]
[/TR]
[TR]
[TD="width: 35%"]Width[/TD]
[TD="width: 65%"]10.4 in.[/TD]
[/TR]
[TR]
[TD="width: 35%"]Depth[/TD]
[TD="width: 65%"]9.3 in.[/TD]
[/TR]
[TR]
[TD="width: 35%"]Height[/TD]
[TD="width: 65%"]4.11 in.[/TD]
[/TR]
[TR]
[TD="width: 35%"]Weight[/TD]
[TD="width: 65%"]5.3 lb.[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD="colspan: 2"]Miscellaneous[/TD]
[/TR]
[TR]
[TD="width: 35%"]Special Features[/TD]
[TD="width: 65%"]Keystone Correction, On Screen Menu[/TD]
[/TR]
[TR]
[TD="width: 35%"]Speakers Output[/TD]
[TD="width: 65%"]3 W[/TD]
[/TR]
[TR]
[TD="width: 35%"]Projection Method[/TD]
[TD="width: 65%"]Ceiling, Front, Rear[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[FONT=Helvetica, 'Trebuchet MS']Asking $1,100. Please contact Rob at (973) 220-0893.
Thanks!
