Tim Joy
Haven't fully tested this, but seems to work well so far, I always get a bit-rate between 18-24 m/b
Directions for use
1. Fill your screen with the above image and stare at it for 3.7 minutes.
2. (optional) Shake your head slightly and defocus your eyes, allowing the image to play tricks on you.
3. When time is up, look back at the D90. Isn't it pretty now?
4. Shoot your scene and enjoy a high bit-rate.*
I tried printing out the pattern on plain paper, but it didn't work as well
as pointing the camera at the screen. I realized that pretty much any
complex pattern works, especially trees with lots of branches. It seems
like the camera determines the bit-rate from the first thing you record.
If you start on a white sheet of paper, it's very low. (4-7 m/b) But, if you
begin recording on something complex and colorful, it's high.
Some things to test-
Does it improve picture quality?
Is the bit-rate is variable, negating the whole process?
Does it affect overheating-
*Might possibly maybe probably only work when shooting complex images, such as the one above. In other words, Production design.
