Mark Kokkoros
What is the recommended method for getting XLR audio (via boom or lav) into the D800? Thanks
I have a camera-mounted shotgun mic and a Sennheiser wireless receiver connected to the XLR inputs of my Tascam DR-100. The Tascam is connected to the Nikon with a Sescom attenuation cable. You don't need a splitter that Tavarino mentioned because the Nikon D800 has a headphone out. I prefer using the audio from the Tascam because the converters are of higher quality than the ones in the camera, but it is easier to sync the two tracks in post if the Nikon records the exact same audio (which also serves as a backup). The photo shows how I mounted everything on my D7000 rig.
http://www.sescom.com/product.asp?item=LN2MIC-TASDR100
The camera records the sound from the DR100 not vice versa, so sound in-camera gets synced to the video and THIS is your reference track for syncing later in post... ;o)I can't quite follow how the camera sound out is recorded on the DR100 when both the shotgun and lav are used, the DR100 being a two channel recorder. Even if it is recorded there is still the sync that is required.
