Hi everyone,
I use to work with "real" video & film camera. And I just bought my first DSLR for video the Nikon D800.
I'm not familiar with DSLR workflow.
Home, where I'll be editing my D800 clips, I run Adobe Premiere PRO CS5.5 (probably upgrade it to CS6 soon) and Avid Media Composer 6 for some bigger work. Everything on PC Computer.
As the compression from the camera is H264 Long Gop, I transcode my D800 clips to a Blackmagic codec and edit it this way.
Is my workflow correct? How can I improve it?
Other question : I can't compress to H264 my final export well. Always, using the same bitrate, 2 passes, the result looks bad.
When I compare the H264 straight from the camera and the export (even without adding any effects) I lose lots of detail. The IQ is a ton lower. (I use Adobe Media Encoder)
Is there a way to have almost the same quality with my final H264 export?
If you have some tips! It would be perfect!
Thanks a lot. (Sorry if my english is not perfect)
