macgregor, can you post a jpg sample of both internal and external frame.
I rated Flaat_10 at 10 stops of DR, there's that extra bit of info you talk about but it's basically useless, it's stored at one or two shades for every stop of light
Flaat_11 is very useable too, and I'd rate it at 11 stops
the higher ones, Flaat_12 and Flaat_13 (12 and 12.7 stops), show a lot of that posterized noise you talk about; they can still be useful, but only with heavy noise reduction; I'm not sure you would like them
http://vimeo.com/groups/137445/videos/41935766
http://vimeo.com/groups/137445/videos/39941831
http://vimeo.com/39899742
and also:
if you're recording internally, my picture-control approach helps because the curve is applied to a better quality image (I think it's uncompressed 422 8-bit), whereas if ou apply it in post you're killing a lot of info and then applying the curve over H.264 8-bit 420
if you're recording externally, I haven't done any tests, but I'd think the picture-control approach wouldn't add a lot (i.e. you can get basically the same applying the curve in-camera with the picture control, or applying it in post)
plus: I see you studied here in Madrid!! are you still around, or did you fly away?
