Here is a short piece I did while playing with the D7100. https://vimeo.com/62541488
It has a ton of DR and I'm getting used how it handles. A few things I do is I switch back and forth between picture and video in live view. That way I can grab the exposure info from the picture mode and apply it manually in video mode. It also helps to have an EVF with zebras and focus peaking. I also assigned the shutter release button to start recording video which makes it quicker to fire up and start recording right away. Playing with custom picture controls and neutral with contrast set to -2 is a lot more forgving on the FPN then setting a flatter gamma curve. Neat video cleaned allot of the FPN up and its common to have to do some post sharpening and noise reduction even with our productions envolving Red Epic, C300, GH2 etc... I just wish there wasn't any of the horizontal FPN with this sensor.Nice! It looks that the D7100 can compete with the big guys.Thanks for sharing!
When you import your footage from the camera, how is the compression and what type is it also. When I get mine, I would just use the in camera compression.
And could you explain the problem of FPN.
thanks
Hi, I found this video on youtube today of a band filmed by the d7100.
http://www.youtube.com/watch?v=Ijuom7MbRes&lc=iNk1ebyREKx3GYqw1Cs3vxpp9nysEGXayUjzbKFP-NU
Is this the flcker you talk about , or just bad exposure?
If you search D7100 and select "today" you can find some new sample of the D7100.
The flicker is LED related. Folks don't realize not any led fixture works. The frequency has top sync with the frame rate. It's got nothing to do with the type of sensor.That seems to be flicker caused by LED lighting...and it would be there with every CMOS camera...
Small rule of netiquette.
Always spell out acronyms and abbreviations in first time use in a thread. What is FPN ?
I don't know how you come up with some of this stuff. LED lights are used all the time in production. Even Arri makes LED lights.... Folks don't realize not any led fixture works. The frequency has top sync with the frame rate. It's got nothing to do with the type of sensor.
The flicker you mention, would it be the same, better, or worse compared to a D600 full frame censor?
Thanks.
And is this common with cameras like the GH3?
And one more question, if the problem of flicker does happen, are you able to see it on your viewfinder while you are filming?
Fluorescents do work. The Kinoflo Diva is just one of many fluorescent lights used in production all the time. The trick is that you have to have right LED and fluorescent lights. Making blanket statements about all LED or fluorescents not working is just not accurate.The statement says: "not any led fixture works" right? Maybe the same way all fluorescent lights don't work well with video?
