D5200 higher bitrare hack also available now
I can tell you that the hack works great on my d600 and my d3200 but playback doesn't work on either camera at this point.
IF they play at all (even for a few seconds) just hit the fastforward button, on my D7000 at 2x the files plays the whole way rather than the 2 or 3 seconds at normal speed (I'm using the 36 bit hack).
Do you know if in-camera playback works with the hacked files? THANKS!!
Few observations noted with the patch:
1. Record countdown starts as usual from 20 mins but stops at 6 mins still remaining. Hence the maximum record duration is 14 mins and the maximum file size is 4GB.
2. Cannot record past 14 mins/4GB even in exFat formatted UHS-I SD Card.
3. Can record for full 14 mins without interruption even in SD card as slow as Class 6 (Minimum performance is 6 MB/s = 48 mbps). I do not have slower card than Class 6 to test.
4. I could playback recorded clips in camera (as long as 10 mins) even in Class 6 SD Card but the camera refused to show preview of 14 min/4 GB file even in UHS-I SD Card by displaying the message "Cannot display this file".
Sample video from user Kelac
http://youtu.be/RP-ugKPNT3g
Are you satisfied buddy with the Hack?
Yeah.. It gives more details and gives u more playground in shadows. And i find out that if u put in camera sharpness to 0 its quite soft image and bitrate seems to be under 40Mbps, but if u put sharpness in camera 3-5, the bitrate is 60-65 Mbps and picture is ALOT more detailed and sharper. :)
Sharpen 0 https://www.flickr.com/photos/terozzz/15207916825/in/photostream/
Sharpen 3 https://www.flickr.com/photos/terozzz/15184885026/in/photostream/lightbox/
Terozz,
Do you know the minimum SD Card speed needed to handle the 64 Mbps video? Will Sandisk Extreme 45 MB/s UHS-1/Class 10 SD cards work?
Wow thank you!
could accour any issues installing the patch? Could i easily Go back to the factory settings?
It works fine with class 10 cards and no issues at all to go back original firmware. But be carefull... Use ONLY original battery when u install hack so your camera wont get bricked. (There is danger if u use 3. party battery and your camera closes while installing it...)
But its safe to use when done right :) Read all info before install hack as allways ;)
Ok i have tried patching on a Mac didn't work so tried on a Windows System it seems to patch and install / update fine, but i see no difference in the menus or recording time to know if the hack has actually been installed properly. I have a D5200 and its on firmware C 1. 02 / L 2. 002. Any idea where i might be going wrong?
Please help.
