Sorry, one last question... Where did you read about using this filter? I mean, everyone must be dealing with this problem. Did you come up with this solution or did you read about it on another forum? I am having problems bringing up any discussions about using these tools to remove moire.
It's not really a solution, it's more like a band aid treatment. The real solution is to use another camera.
It can make some footage "usable", but as you may be noticing, it's quite slow to process. If you want slightly better results, use a slower preset setting in QTGMC; "slow" was the fastest one that gave acceptable results. If you read the .avsi or the documentation you will notice there are dozens of settings you can tweak to customize for your footage
Anyways, I use avisynth for a bunch of other stuff - and it has filters for many situations you might encounter in video processing , so I just applied some filters that I had used in restoring some old DVD's (just tweaked the settings abit). It's very powerful stuff, but not very user friendly - there is no nice GUI or buttons to push like some expensive plugin for an NLE or AE
