i am trying to get the Deg on the display rather than the sec. i have selected [SCENE FILE] menu → [SYNC SCAN TYPE] to deg, however it still is displaying 1/60 on the display.
i thought it was there at one point, now only secs.
Inger
You may have changed your scene file since setting that menu item. There are six scene files, and each one has its own SYNC SCAN TYPE. If you changed to a different scene file, that would explain it.
Or, the other option is that you changed the shutter speed away from the Synchro Scan speed. The DEG only works for when the shutter is set to the SYNCHRO SCAN setting. Try changing the shutter speed to be the one just after the very fastest shutter speed, and right before the slowest shutter speed. That will be the Synchro Scan speed, and if you have the SYNC SCAN TYPE set to DEG, then it will show the shutter speed in degrees.
thx Barry, i had to roll it past the Highest. i was kinda expecting that once in 180deg, a simple roll of the shutter would put me to 120d, 108d, 90d or the other way 216d, 240d and so on like i do on my GH5. instead it is fine tuning i gather for rolling screens or light strobing.
