CVP Editor
Archduk3
*EDIT*
I found the old thread but I can't delete this one.
*EDIT*
Hi everyone,
Like the idiot I am...I of course already update all my system to 64-bit only....so running the CVP editor for the F35 is pretty much impossible unless I invest in a new computer...or rather an old one.
For now though, since I don't have access to this, can anyone confirm the way files are transferred from the editor to the camera. Are you connected through the app or are you still using the web interface?
Have you had any luck reading .lut files from in the editor? Because then technically I feel we should be able to add both SLOG2/3 to the F35...even if it means forcing into custom mode.
The main thing I need it for now though, is to create a new MLUT for monitor out.
C
In the past I used a Sony memory card to transfer new curves. I'm pretty sure the software won't allow you to create a gamma curve beyond 1000% or 1200% percent. Slog was originally designed to map the entire range that the chip could capture, so not sure if there there is any benefit to creating a flatter curve.
