Custom made steadicam components
charles
If you're interested in any of these items please let me know. I've used a water jet to cut these. During the process I made 20pcs 15mm & 19mm brackets. Some I've sold. Each bracket set will include two 6mm Allen screws that will lock down on both brackets to secure the rod in place. It works beautifully. This can be very useful for mounting a monitor bracket or a battery system under the sled. The brackets are sand blasted, primed and painted black.
Custom brackets for steadicam or non-steadicam system
1. 15mm & 19mm brackets are $60 a pair:
2. Vest components:
I am selling 3 of these vest plates. The holes where just wrongly placed. Besides that, nothing else is wrong. These plates are exactly the same as my plate I made for my EFP vest. The plates were cut using a water jet. Could be useful to someone. These were part of a first production run but were put to the side due to the hole placement. The plate also includes the spar for up & down adjustment which are primed in preparation for painting. Selling both Vest plate and Vest spar.
The height vest plate is 280mm
The width of the vest plate from peak to peak is 240mm
The vest spar is 320mm in length
The angle of the two peaks are 15 degrees inwards.
Holes are for 5mm & 6mm bolts.
The pics below show the vest without the paint and the other with the paint.
I'm selling both vest plate and spar for $70
Custom built 'Steadicam' type Arm/Vest arm Bracket:
I'm selling 8 vest/arm brackets. I have 2 different designs. The buyer can certainly re-adjust the holes to fit their needs. You may make new holes for your socket block but you will have to do your own measurements. A professional machinist can help you with it.
Length of the brackets are 190mm
Width of brackets are - Min: 60mm & Max: 80mm
Angle of brackets are 15 degrees
Thickness is 6mm
Four mounting holes via connection to the vest is 8mm
I'm selling them for $30 ea.
I'm also selling a complete set of 2 50cm carbon rods and a pair of 12mm brackets on E-bay:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=120476451851&ssPageName=STRK:MESELX:IT
Good to hear. I can also do a package deal if you like. like i said i have made 20 pairs of 19mm rod brackets. So do not hesitate to buy more.. Ha ha
