SOLD Custom Built 3-Axis Brushless Gimbal
Status
Not open for further replies.
NextWaveG
The gimbal is a “Hifly” brand kit. This kit originally included:
- 4pcs Motors 8108-90T
- Alexmos 8-bit 3-Axis controller & IMU
- 11.1v 10,000mah Battery
- Carbon Fiber Frame
- Camera Tray and Tilt Bar
What has been upgraded:
- Custom Controller and IMU Housings
- Machined Aluminum Roll and Vertical Arm
- Custom Joystick and Menu Button
The original cost of the gimbal was $1800. I’ve since spent over $500 on upgrades. We’ve also spent dozens of hours configuring and calibrating the system. You will receive a gimbal that is ready built and partly calibrated. All you’ll need to do is balance and calibrate it for your camera.
I’ve also included extra nuts and bolts that we’ve used to upgrade from the cheap Chinese ones that came with it. Also you’ll find the original carbon fiber roll bar and vertical arm included as extra parts if you need them. The upgraded aluminum ones are stronger, offer less chance for twisting and match the design of the Movi.
Important note: Gimbals do require some expertise to setup and operate. You will need a computer to connect via USB for calibrating the motors. This may take some time to setup initially, but is usually much faster once you’ve done it a few times.
I’m selling the system as I’m investing in a more expensive gimbal that is a little faster to setup on set and faster to calibrate when swapping cameras. We’re starting to work on productions that every few minutes counts on and that warrants spending more on higher-end gear.
I’m asking $1400 via PayPal (shipped continental US).
Email tony@nextwavedv.com if you’re interested. Thanks!
Camera, lens and light stands not included.
Click here for more pictures.
Status
