cukoloris pattern & making one...
matthewd5
i am going to take a stab at making a cukoloris (it is one of those things that is a large rectangle with lots of patterns cut out of it to make the light in the background look shadowy and "random"...
does anyone have a pattern or any firsthand experience on making one?
hopefully walter will share some of his expert experience on this??
matthew
Re: cukoloris pattern & making one...
When we've had to make 'em in the field, we just use a pocket knife and some foam core, cutting out camouflage-type patterns. When we didn't have foam core, we did it with black wrap.
The two patterns we use most are the venetian-blind pattern and the camouflage-style pattern.
Mat,
you heard it already, cut some foam core into shapes. That's what I use in my kit every day.
i was planning on using generic foam core from staples. stuff is good for so many different purposes.
just figured i would check for a pattern but i guess they aren't that complicated.
matthew
hmm. good idea.
where do you get black foam core? all the stuff i have seen is white?
what is the easiest way to hold one up? i hate to waste a light stand just to hold it.
matthew
Hold it up with a c-stand. Black foamcore can be bought at art supply stores.
i found an accessory for my bogen superclamp, it is a 21" flexible arm that looks like it would hold a pretty decent sized piece of foamcore.
i checked my local office supply company and they list foamcore in black, white and even grey!
matthew
what's the grip foam core holder called...a duck bill? I can't remember right now.
Here is a pattern someone sent me to show that they were making cukes like me. But this is a better quality than what I make. I don't frame mine. I simply cut patterns and use them till i abuse them then throw them out. The frame is an excellent idea as you can simply replace your foamcore when needed in the frame.
http://www.pennastudio.com/misc/cukaloris.jpg
Yep, a duck bill aka a Quaker clamp. Looks like a vice grip with big flat plates attached to the jaws and a stud. Not as fancy, but cheaper is a Cantrell holder--a shaft with two big flat plates.
My grip lingo lexicon has seriously eroded from being stationed at this desk.
isn't it called an alligator clamp? I used to hold foamcore with those, if I'm not mistaken...
 an alligator clamp has teeth in it along the edge of the clamp, and is most often long and narrow for biting into what its clamping to suffice a sure grip on it.. like the type of clamps found on an ohm meter or voltage tester.      ..a duck bill has a flat and broad clamping surface so that it does not mark or mar or crush the clamped item.
My favorite stand for foamcore is the ever-famous "Hey you! Hold this right here. Ok, now don't move for about 15 minutes."
[quote author=HorseFilms link=board=lighting;num=1101173504;start=0#14 date=11/23/04 at 09:23:21]My favorite stand for foamcore is the ever-famous "Hey you! Hold this right here. Ok, now don't move for about 15 minutes."[/quote]
Or in the case of a foamcore cookie, "Yes, I *know* the skin on your arm is starting to blister, but please hold that cookie a little steadier. And action!"
[quote author=iamloser link=board=lighting;num=1101173504;start=0#13 date=11/23/04 at 07:48:00]  an alligator clamp has teeth in it along the edge of the clamp, and is most often long and narrow for biting into what its clamping to suffice a sure grip on it.. like the type of clamps found on an ohm meter or voltage tester.      ..a duck bill has a flat and broad clamping surface so that it does not mark or mar or crush the clamped item. [/quote]
Ahhh. We just call them Both Alligators ("Garra Jacaré") here, but it certainly makes sense.
well i built my first prototype, as i expected cutting the foam board is a pain in the ass. takes at least 2 or 3 passes to get all the way thorough.
holding it was pretty easy, i made two squares out of scrap that are 4"x4", one on each side of the foam board and i have a small plastic work clamp with the 5/8 spud.
to mount it to the camera i used two matthews grip heads with a 12" piece of stainless that came out of my filmtools.com car mount and i used a bogen superclamp to attach it to the base of a lightstand.
i couldn't bear wasting a light stand just for the cukoloris.
i'd love to find a more effective way to cut out the foam board.
matthew
"i'd love to find a more effective way to cut out the foam board. "
A serrated steak knife works well. Best to take your time and stencil out suggested patterns before you cut. The more time you take, the better the cuke.
I was just doing some website updating and realized I had a little clip with a cuke being used. If you want to see it, go to www.bluesky-web.com/ click examples and scroll down to about the middle where it describes a hilarious piece I created for a pilot. The photo is of a African american girl and guy.
