greeches
I ran into something I don't understand, so please enlighten me!
I was doing some tests recording the following to compare:
5Dmk2 - ML + Remove Overlays -> Internal Codec
5Dmk2 - ML + Remove Overlays -> Ninja2 Recorder
[Internal]
[Ninja2]
If you look at the bottom of the alcohol bottle you can see the difference in viewing angle. I had a 20mm f1.8 lens on there.
Is it possible that I'm getting more of the viewing angle of the lens when doing this? How is this possible?
[Internal]
[Ninja2]If you look at the bottom of the alcohol bottle you can see the difference in viewing angle. I had a 20mm f1.8 lens on there.
