cardmaverick
Director of Photography Chris Nuzzaco (www.chrisnuzzaco.com) is crewing up for a busy 2008 shooting schedule. He has shoots in several states along the east coast.
Due to several upcoming shows and varying schedules, Chris is looking for multiple Gaffers, Key Grips, AC's, and Grips.
Gaffer:
The ideal candidate should be able to use a light meter (both spot and incident), have a keen eye for lights finer qualities, and be able to communicate technically with the DP. Experience with 5K fixtures and larger is highly desirable, but not always a requirement. Must be able to safely operate a generator and understand how to safely and efficiently use location power.
Key Grip:
The ideal candidate should be able to work successfully with the Gaffer and DP in order to rig setups that are safe and efficient. Experience rigging wall spreaders, boom stands and heavy fixtures (10 lbs and up) is highly desirable. Condor crane experience is also desirable.
AC:
The ideal candidate should be familiar with a film style work flow. Experience with 35mm adapters and 35mm lenses is desirable. Experience using a slate is an absolute must! Some training will be required for shows using a special RAW HD camera.
Grip:
The ideal candidate is experienced with common industry grip gear, knows how to use it safely, and won't break it. Ability to follow direction is important.
How to apply:
Please read these instructions carefully! If you can't follow these simple instructions, you probably wont find yourself on my crew.
Please respond via email with your resume, contacts, and any links to past work online. Be sure to state where you currently reside. Put the title of the position your applying for and your location in the emails subject line. Send your email to: filmgigs@chrisnuzzaco.com
Gaffer:
Key Grip:
AC:
Grip:
How to apply:
