bitcrusher
What if you modified the gate on a 4 perf camra like a KONVAS 1M to 18.6H X 10.5W so you would be shooting a horizontal rectangle and then Flip the camera 180 degrees. So it would be 10.5mm high X 18.6 wide. When you are finished with one side of the roll then you just expose the other side like an old 8mm camera.
You would also need to to re-center the mount, and figure out a new tri-pod mount.
No need to mod the gears to get 2 perf movement, but this would only work with something like a Konvas or a Eyemo. It would be way too unwiledly to shoot with a large camera this way.
Would something like this work?
