Crappy look.
jigmic
I've seen works in the "Grabs" forum and my video,filmed doesn't look like their's. 've tried factory settings, settings that people filmed with that looked good and it looks crappy. I even lite a scene with 500 watts and it didn't look good. I've talked to people that run-n-gun, with whatever lighting is available(not their own lighting) and it crushes mine. Could there be something wrong with my camera or can I get some tips on setting and lighting for indoor and night shots?
Re: Crappy look.
It's hard to say. Do you notice a difference when you change settings? It's always possible that there's something wrong with the camera, but I would say it's more likely the way you are shooting. Just using one 500w light isn't necessarily "lighting". In fact, just shining a flood on something can make it look crappy.
I would set up your camera in a room and experiment a bit. When I got my camera, I set up my kids 4 foot tall spiderman in a chair. I set up my tripod and shot from the same spot with different settings. Then I changed the lighting and did it again, and again. The whole time I talked to myself about what I was doing with the iris, the scene file, the focus and zoom and the lights. So when I watched the tape I could see what settings and lighting set-ups were getting results I liked. I've done the same thing outdoors to experiment with the ND filter as well as a polarizer through a car window. Of course that time I forgot to reset my audio settings. The night before I had been checking sound with my shotgun mic, and forgotten to turn the camera mic back on, so I had to guess at what I had done.
Anyway, that's what I would do. Try lots of different things, but keep one thing, like the location of the camera, constant. It may give you a baseline to see what's working and what isn't.
Of course if it is the camera, that's a different story, but this exercise should help determine if it's your technique or not.
I would also recommend you browse through a lot of these posts. I've learned a lot of tips and trick that I was able to try out right away.
Good Luck
Re: Crappy look.
Honestly yeah, it depends on *how* you're lighting the scene, having it be bright doesnt mean it'll look good :-/
I highly doubt that it's a settings issue, or the camera itself, because no offense, but you're saying that "you lit it with 500 watts." That doesn't say anything except that you had a bright set.
Can you post some frame grabs of your clips so that we can see for ourselves - maybe you're also just overly critical of yourself!
If you search the forums there have been several books on cinematography that have been recommend - learning from the greats (something like Storaro's "writing with light") can only help!
Re: Crappy look.
Thanks Jim for taking the time to write about my problem. I will try what you say and let you know. Also, you said that you had to reset your camera mic before shooting. My sound is terrible. I have trouble picking up sound. It sounds like an old VHS camera, low with echos. I filmed the same scene, with the distance the same but, different angles with a GL2. The sound on the GL2 was far superior. Can you help with this problem?
Thanks, Mike!!!!
I will post the best shot I have and you can look at it. Let me know what I'm doing wrong. Also, is there a crash cousre on how to upload my gram on this forum? I am new to all this.
This site is sooooo awesome!!!! I love how people help each other for the common cause. Good movie making.
Re: Crappy look.
Don't know about your mic. I don't do anything to mine, except have it set to ...line? sorry I don't have it in front of me. But if you are getting sound without hooking up a mic, you're getting it from the camera mic.
If you go to the screen grabs section, there's a tutorial about uploading. Keep us posted
