Ted Spencer
In very early testing with my HVX (just got it a week ago) I've noticed a couple of thing regarding the analog component (RGB) outputs that I thought I'd compare notes on with others here. In all cases I'm talking about shooting 24f/720p, either pN when recording to P2 or p when recording live into FCP via firewire:
1) Frame rate from real-time camera output: it appears on both my Panasonic 42" plasma screen and my Sony HT75W 17" widescreen LCD (used by numerous others here) that the display frame rate live from the camera is reduced somewhat. A noticeable motion-stroboscopic effect is visible when viewing either of the monitors that is not visible on playback in Mac/FCP after live capture, nor is it visible when playing back from P2 to the plasma or Sony. The same effect is also visible in the onboard LCD.
2) Brightness: the real-time component output from the camera looks absolutely sensational, but seems to be unrealistically bright. It's much darker viewed on the Mac/FCP both before and after capture, and also when output to DVD and viewed on the plasma or Sony. Here's a description of an admittedly quick, informal test I did:
First I connected the component out of the camera to both the Sony 17" and the 42" plasma and adjusted both for a pleasing image, matching color, brightness and contrast to each other as closely as possible. I did this two different ways, using a freeze-frame from an HD source (an HBO movie) on my HD cable box. I plugged both monitors simultaneously into the cable box's component out using 3 y-cables (which admittedly degraded the signal, but presumably did so the same for both monitors) and matched them. I also plugged them in one at a time to make sure they still looked matched after they got their proper signals back, and they did, as well as I could determine given the time lapse between viewings (it was in this part of the test that the "pleasing image" determination was verified, not in the degraded, y-cabled part).
Next I recorded some 24/720p footage via firewire directly into my Mac/FCP rig (Dual 1GHz G4/FCP 5.1.2). It looked much darker there than on the camera's component output to the Sony, which was sitting right beside it, even with the computer monitor's brightness (a 22" Apple Cinema Display) turned all the way up. I then used Apple's Compressor app to create a widescreen DVD ready file at the highest possible quality and resolution settings, imported it into DVDSP and burned a disc. I played it on my Pioneer Elite DVD player back on the plasma screen (via component) and the image was again much darker than the live camera output, roughly equivalent to the FCP/Cinema Display. The Sony HT75W produced similar results.
I do feel that the test setup eliminated the obvious other explanations, such as simply having the plasma or Sony's brightness up too far to begin with.
What I've concluded from this is that at least in practice, the HVX's analog component outputs appear to be unrealistically bright - that the actual image, once captured and played back on other systems and devices is much darker.
To avoid being misled by this, and consequently underlighting a shoot (a mistake you don't want to make with a 1/3" CCD HD camera), I've concluded that I will have to use adjusted settings on external monitors to compensate - settings a good deal darker that what looks right for other playback situations, such as viewing a DVD movie or HDTV. I spent a fair amount of time comparing live componenent output to captured/DVD playback, and came up with some settings on the Sony (it will be my primary shooting monitor) that address this issue, which again, is mainly a matter of lowering brightness (although once I did that some other settings inevitably needed to be compensated). After making the adjustments, I feel I have a workable solution, but it's not ideal. Ideal would be if the live output's brightness matched the other monitoring scenarios, but it doesn't, and there is no provision (that I know of) to adjust the camera's component out brightness.
Lastly I want to mention that I know that neither the 42" plasma nor the Sony LCD are "broadcast-quality" monitors. I don't plan to make hyper-critical decisions on a shoot about color, etc. using them. In that regard, they're a compromise I hope to be able to work reasonably well within. But the brightness discrepancy does appear to me to be something of a different animal...
So the simple question that follows this long-winded explanation is:
Anyone else have this issue?
Thanks!
Thanks!
