Green Hornet
I was recently testing a Canon HF s100 and it divides the AVCHD footage at 2 gigs (from what I remember). THe HMC150 seems to divide the footage at 4 gig sections.
I was wondering if a firmware change could change this on the HMC150?
I would prefer that it could be divided at even lower amounts, like 1 gig sections.
The reason for this is that is sure seemed easier to edit the Canon AVCHD footage, as I could transcode or use smaller sections of footage, and not use other sections.
If out of a 4 hour shoot, I only needed selective 15 minute sections, it sure makes things easier doing smaller chunks.
With 4 gig chunks, you have to process the whole thing in order to cut out the smaller section. Sure you would have more single pieces, but works for me.
Also what is with the nameing sequence when transcoding to DVCpro HD?
It seems as if there is no way to know the order if you put the footage in the same folder.
