Bruce Watson
This sounds horribly naive, but what's the industry standard way to sandbag a c-stand?
What I've read is that you should bag the longest highest leg, because that will keep the sandbag off the ground so the leg carries all the weight. I get that.... but wait. Isn't the longest leg supposed to be under the load? If I've got a grip arm out 40" or so, with a flag attached, the c-stand is off balance (which is why I want to sandbag it). I'm thinking the longest leg would be directly under the grip arm, because this will make it harder to tip over. But putting the bag on the same side as the load... I would have thought that you'd want to put the bag on the side opposite of the load, to keep the center of gravity as close to the riser as you can.
So clearly, I need a c-stand lesson or two. Oddly, I've been googling around and not finding anything out about this. Must be to elementary to teach. Sigh...
Example: You've got a flag out at the end of a grip arm that's horizontal to the ground. What's the best practice for which legs go where (relative to the grip arm), and where's the sandbag(s) used?
