Hello,
I'm pretty new to all this so here are some basic questions:
I just wanted to check with the pros that i was using the correct settings to capture my footage into Final Cut 6.
My camera is a DVX100B, so it's PAL and i'm using 25p progressive setting in my scene file, and i shoot in the squeeze mode 16:9.
In Final Cut 6, i use the easy setting called DV/Panasonic DVCPRO, then 25 fps, then DV -PAL Anamorphic.
First could you confirm to me that that's ok?
Then, how does it know that i'km using progressive mode?
Then, what's the Cinema Tool for? I read it's converting 25p to 24p ... do I want that? should i use it for anything in particular here? Will it help me get even more movie "look" ?
Note: I would like to output PAL DVDs in 16:9 ...
Can anyone guide me?
Thanks,
Kat
Thanks,
Kat
