COPYING MINI DV
  • Start date Start date
G
Guest
Guest
HEY GUYS. I'VE GOT A SLIGHT 'TIME IS OF THE ESSENCE' SITUATION ON MY HANDS.
WHAT'S THE QUICKEST WAY TO MAKE FULL COPIES OF MINI DV TAPES WITHOUT LOSING QUALITY?
CAN YOU RECOMMEND A PLACE IN NYC?
Re: COPYING MINI DV
Far as I know, it's as simple as hooking up two MiniDV cameras with a 4pin-4pin firewire, hitting "play" on one and "record" on the other.
Re: COPYING MINI DV
Yeah 2 cameras does the trick, but if you want an identical copy (data track and timecode) the only prosumer camera that can do that is the DVX, or you can use a pro deck to dub them.
Quality wise though, even 2 $400 cameras will give the same picture quality as a $10,000 deck, because you are dubbing lossless digital bits. Just keep an eye on dropouts.
