stevedocmaker
Set of 2 LED 600 lights (daylight) made by Cool Lights. These are high quality units. The manufacturer claims a CRI of 82 which is probably accurate. The color temperature is approximately 5000 degrees. They made 2 versions of this unit, these are the "spot" version (tighter beam, possibly a 60 degree spread but I'm not sure). Each unit is metal with 4 bank switches, a master switch and a dimmer. Each weighs about 3.5 lbs. They are very well made, and throw a very good quality of light. If I recall, they each pull about 45 watts. The set will come with 2 600 LED units. 2 barn doors, 2 sets of plexiglass filters (1/4 minus green, 1/2 minus green, and CTO), 2 power supplies, 2 soft cases and one softbox with diffuser and a soft grid attachment. One of the units is missing one of it's two spring clamps that holds the filters or barndoors in place, but it's still perfectly functional as only one is needed.
$750 including shipping to ConUS. For fastest response, contact me via email: steve@differentialfilms.com.
