STEproductions
Hey guys,
I know this topic has been covered several times, and I spent a lot of time yesterday doing searches, but I've still got a specific problem that I couldn't find and answer to. I have a bunch of 7D footage a friend gave me that I'm going to be editing in FCP 7, and I'm trying to nail down a good workflow that I can come back to for future use. I was able to do it in Compressor, and MPEG Streamclip, but I'd like my conversion solution to just stay in Final Cut. I also noticed that Compressor and MPEG slightly altered that color, where doing it directly in Final Cut didn't seem to.
I downloaded the software release from Canon (The E1 EOS Movie Plugin), which allows you to make the conversion using Log and Transfer. Now, I don't have the Camera or card, I just have a harddrive with the files. Canon makes it clear though in the most updated version of this Plugin (April), that you do not need to have the entire card (or a copy of it), and that you should be able to just drop 7D files in H.264 format, into your Log and Transfer. Then you should be able to go into preferences (the gear thing in the top left) and select the Canon plugin, and select your type of ProRes (HQ, LT, Proxy, etc.).
This is about as far as I can get with this method. When I click on the "Add File" button on the top left of Log and Transfer, I then go through my computer and locate the folder with my H.264 files, but when I find them they are greyed out, so I can't click on them. When I try just dragging and dropping them into Log and Tranfer, the wheel starts to spin, and a message saying "Adding file" displays, but after about 1 minute, FCP with just should down. After it closes, it says there was FCP experienced an error with the Canon E1 plugin.
I called a friend at this point who is an experienced FCP user, and after talking about the problem for a few minutes, he told me to just use a different method entirely. He showed me how to go into your Final Cut browser, and do a batch export of your H.264 files, using the desired ProRes codec. It allows you to choose the destination folder to export to, and seems to work just great. I just found it weird that in all my searching, no one else mentioned this method. What are you guys doing?
My one hold up is that is seemed to take a while to do... Maybe Compressor, MPEG Streamclip, or the Log and Tranfer with Canon Plugin are faster methods. It probably took 4 or 5 hours to convert about 2.5 hours of footage. The result is great though. I'll be happy continuing to use Batch Export to convert my H.264 clips, I just wanted to know if there are any potential problems with this method that I haven't encountered yet.
Scott
Scott
