So, when it comes to sound, I admit I need to learn more. So my question is, if you convert a 44.1 sound file to 48, does that change the duration of that file?
The reason I ask is the show I am working on, I am given a leica quicktime sequences of the episode with the audio at 44.1. With these I receive wavs of the entire sequences audio, with each characters voices isolated to a track.
In all other cases these are sent as 48k, however, these ones were sent as 44.1.
My procedure is to take the qt, convert it to the codec I use and convert the QT audio to 48. I then line up the wavs, to the quicktime to make sure everything is in sync. The odd thing is that with these, when I try to convert these wavs to 48, they do not match the qt audio, (even though I converted it to 48) but slowly drift more and more out of sync the further down the timeline you go.
I use QTpro to convert these files. Is there something I am missing here? Should I use a different program to convert?
Any suggestions would be greatly appreciated.
Thanks in advance.
Jeremy
Thanks in advance.
Jeremy
