SOLD Convergent Design Odyssey7 OLED Monitor/Recorder at Texas Media Systems
Status
Not open for further replies.
Trotter G
Convergent Design Odyssey7 OLED 7.7" Monitor/Recorder - $1195
For sale is a demo model Odyssey7. Never even been turned on. This is an essentially new item with box and all accessories. I also have SSDs for sale.
PM or cal 512-440-1400 for details. Ships free UPS Ground, US only.
[h=3]Features:[/h]Display: 7.7" OLED, 1280x800, RGB 8-Bit, 3400:1 Contrast, 176� Viewing, True Blacks
SDI Video I/O: SD/HD/3G Support: Single/Dual Link, 2-Inputs, 2-Outputs
Odyssey7Q adds 2 Bidirectional HD-SDI 3G ports to allow: 4 HD-SDI 3G Inputs, and 2 HD-SDI 3G Inputs or 2 HD-SDI 3G Inputs and 4 HD-SDI 3G Outputs or other configurationsSDI Video Formats: HD/2K RGB 444 8/10/12-Bit up to 60p/60psf, HD/2K YCC 422 8/10-Bit Up to 120p, QHD/4K 422 up to 30fps, ARRIRAW (16:9) 12-bit up to 60fps, ARRIRAW (4:3) 12-bit up to 48fps, Canon Raw QHD/4K 10-bit up to 60fps
HDMI Video I/O: HDMI I/O Version 1.4a support
HDMI Video Formats: Up to 1080p60 422 8-bit
LUT Support: ARRI, Canon, Sony
Monitor Analysis Tools: Focus Assist, YRGB Waveform, Histogram, False Color, Vectorscope, Zebras, H/V Flip/Flop, 1:1 Mode, Recticule Markers, Horizon Indicator
Odyssey7Q adds ability to monitor four video streams in a quad-split displayRecorder Options: Avid DNxHD up to 1080p30/1080i60, HD/2K Uncompreseed RGB 444 up to 60fps, HD/2K Raw up to 120 fps, ARRIRAW (16:9) up to 60fps, (4:3) up to 48fps, Canon RAW QHD/4K up to 60fps
Odyssey7Q adds Four Stream recording up to 1080p30, 4K Support, High-Speed (120fps) and Simultaneous RAW + Proxy (DNxHD-36) modeRecord File Formats: DNxHD = .mov, Uncompressed = .dpx, HD/2K Raw = .dng, Canon Raw = .rmf, ARRIRAW = .ari
Record Triggers: Touchscreen, SDI record trigger (ARRI, Canon, Panasonic, Red, Sony), Optional remote cable
Digital Audio I/O: 2-Channel Embedded Audio (48KHz, 24-bit)
Odyssey7Q adds 8-Chan supportAnalog Audio I/O: Mono Speaker, 3.5mm headphone output, mono unbalanced consumer input
Remote Control: RS-232 I/O, programmable GPIO
Timecode: LTC I/O (BNC) or Embedded SDI/HDMI TC
Wireless Control: Bluetooth LE with iPhone/Android App
Recording Media: 2.5" professional server grade SSD in 240/480/960 GB sizes, 500MB/sec read/write speed, SATA-3 (6 GHz) interface, compatible with off the shelf USB 3.0 and Thunderbolt adapters
User Interface: Capacitive Touchscreen, Two mechanical Function Keys
Firmware Updates: Via USB Port to host computer, download updates from website
DC Power Input: 10 to 34 VDC with built-in reverse polarity protection; built-in power switch
Power Dissipation: 8 Watts (monitor only), 8-15 Watts (monitor and record mode)
Weight: 540 grams / 1.2 lbs, cast-magnesium case
Size: 7.9" x 6.1" x 1.0" (200 x 155 x 25 mm), measured from end of BNC to SSD tabs
Environmental: -10 to +40�C (Operating), -20 to +70�C (Storage)
Status
