SOLD Convergent Design Odyssey 7Q+ 4K Recorder/OLED Monitor w/two 256GB drives at TMS
Status
Not open for further replies.
Trotter G
Convergent Design Odyssey 7Q+ 4K Field Recorder/ 7.7" OLED Monitor w/ Two Free 256GB SSDs - $2195
This is a display unit with hardly any hours powered on (zero hours of recording). Never registered so it has a full new warranty.
With the firmware update it's now compatible with select Samsung SSDs, additional Anamorphic De-Squeeze options - Center Extraction, Hyper Zoom, and Exposure Compensation LUTs.
Ships free UPS Ground, US only.
HDMI and SDI I/O: HD/2K/UHD/4K Recording over HDMI or SDI w/ conversion
LUT Support: ARRI Log-C, CANON C-Log, SONY S-Log, S-Log 2, S-Log 3
Aspect Ratio Guides: Standard and Custom (user adjustable), may be used for framing guides, Horizontal/Vertical Framing Guides Available
Focus Assist: Video + Edges (Peaking), Edges Only, Enhanced Edges, user choice of color: Red, Green, or Blue
Zebras: Adjustable zebra exposure indicators
False Color: False Color with 5 programmable levels
Waveform: Luma only, RGB Parade, Red only, Blue only, Green only, Full Size and Compact Size options
Histogram: Luma only, RGB Parade, Red only, Blue only, Green only, Full Size and Compact Size Options
Pixel Zoom: 1:1 and 2:1 Image Magnification with frame drag
Output Downscaling: Output 1080p HD via HDMI or SDI from 4K/UHD source (allows for additional on-set monitoring)
Multi-Stream Display: Display four simultaneous 1080 or 720 HD streams, HD-SDI and HDMI inputs supported in multiple formats
Digital/Analog Audio: Multi-channel audio support via SDI, HDMI or 3.5mm analog ports
Timecode: Timecode: LTC I/O (BNC) or embedded timecode via HD-SDI & HDMI (limited to specific cameras)
Record Triggers: Touchscreen, SDI record trigger (ARRI, CANON, PANASONIC, RED, SONY), HDMI (SONY, CANON, PANASONIC), Timecode
In/Out Markers: In/Out markers set during recording can be used during start/stop/playback and exported to NLE.
Upgradeable: RAW Recording Options available for purchase or rental through our website. (Sony RAW, Canon RAW, ARRIRAW, POV Raw)
Dual SSD Support: Dual drive architecture allows for long record time, high frame rate and high data rate recording.
Rugged Design: Magnesium alloy case for extreme durability in harsh conditions
Status
